Time Before: 0.00284 seconds
Time After: 0.02397 seconds
Time Taken: 0.02114 seconds
Memory Before: 1,253.375 KB
Memory After: 2,644.078 KB
Memory Used: 1,390.703 KB
Time Before: 0.02407 seconds
Time After: 0.02553 seconds
Memory Before: 2,644.039 KB
Memory After: 2,645.016 KB
Time Before: 0.02581 seconds
Time After: 0.02596 seconds
Memory Before: 2,645.656 KB
Memory After: 2,646.180 KB
Time Before: 0.02674 seconds
Time After: 0.02936 seconds
Time Taken: 0.00263 seconds
Memory Before: 2,649.047 KB
Memory After: 2,649.969 KB
Time Before: 0.02602 seconds
Time After: 0.03453 seconds
Time Taken: 0.00851 seconds
Memory Before: 2,645.461 KB
Memory After: 3,726.742 KB
Memory Used: 1,081.281 KB
Time Before: 0.03897 seconds
Time After: 0.03942 seconds
Memory Before: 4,289.578 KB
Memory After: 4,418.109 KB
Memory Used: 128.531 KB
Time Before: 0.04201 seconds
Time After: 0.04333 seconds
Time Taken: 0.00132 seconds
Memory Before: 4,302.133 KB
Memory After: 4,429.906 KB
Memory Used: 127.773 KB
Time Before: 0.03811 seconds
Time After: 0.04362 seconds
Time Taken: 0.00551 seconds
Memory Before: 4,282.258 KB
Memory After: 4,415.133 KB
Memory Used: 132.875 KB
Time Before: 0.05066 seconds
Time After: 0.05095 seconds
Memory Before: 5,051.648 KB
Memory After: 5,180.078 KB
Memory Used: 128.430 KB
Time Before: 0.06104 seconds
Time After: 0.06239 seconds
Time Taken: 0.00136 seconds
Memory Before: 5,529.375 KB
Memory After: 5,529.969 KB
Time Before: 0.07315 seconds
Time After: 0.07329 seconds
Memory Before: 6,714.914 KB
Memory After: 6,715.344 KB
Time Before: 0.07551 seconds
Time After: 0.07700 seconds
Memory Before: 6,998.859 KB
Memory After: 7,000.547 KB
UPDATE session SET lastactivity = 1764644049, location = '/forums/private.php?do=newpm&explain=1&u=28660' WHERE sessionhash = '4f5ac0c3684d2f1f18a6fd6fc647414e'
Time Before: 0.09208 seconds
Time After: 0.09328 seconds
Memory Before: 7,516.148 KB
Memory After: 7,516.375 KB
