Time Before: 0.00515 seconds
Time After: 0.00956 seconds
Time Taken: 0.00440 seconds
Time Before: 0.00965 seconds
Time After: 0.01004 seconds
Time Before: 0.01026 seconds
Time After: 0.01038 seconds
Time Before: 0.01116 seconds
Time After: 0.01344 seconds
Time Taken: 0.00228 seconds
Time Before: 0.01044 seconds
Time After: 0.01807 seconds
Time Taken: 0.00764 seconds
Time Before: 0.02385 seconds
Time After: 0.02409 seconds
Time Before: 0.02665 seconds
Time After: 0.02782 seconds
Time Taken: 0.00116 seconds
Time Before: 0.02299 seconds
Time After: 0.02801 seconds
Time Taken: 0.00502 seconds
Time Before: 0.04002 seconds
Time After: 0.04020 seconds
Time Before: 1.79719 seconds
Time After: 1.79878 seconds
Time Taken: 0.00160 seconds
End call of global.php: 1.8012571334839
Time Before: 1.80699 seconds
Time After: 1.80711 seconds
Time Before: 1.80933 seconds
Time After: 1.81081 seconds
SET lastactivity = 1776904031, location = '/forums/private.php?do=newpm&explain=1&u=28661', badlocation = 1
Time Before: 1.82667 seconds
Time After: 1.82691 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 1.8255960941315 seconds with 9 queries, spending 0.0077943801879883 doing MySQL queries and 1.8178017139435 doing PHP things.
