Time Before: 0.03104 seconds
Time After: 0.03667 seconds
Time Taken: 0.00563 seconds
Time Before: 0.03674 seconds
Time After: 0.03730 seconds
Time Taken: 0.00056 seconds
Time Before: 0.03761 seconds
Time After: 0.03777 seconds
Time Before: 0.03855 seconds
Time After: 0.04047 seconds
Time Taken: 0.00192 seconds
Time Before: 0.03783 seconds
Time After: 0.04494 seconds
Time Taken: 0.00711 seconds
Time Before: 0.05492 seconds
Time After: 0.05565 seconds
Time Taken: 0.00073 seconds
Time Before: 0.05813 seconds
Time After: 0.05935 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.05393 seconds
Time After: 0.05956 seconds
Memory After: 2,261.836 KB
Time Before: 0.10539 seconds
Time After: 0.10556 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.12550 seconds
Time After: 0.12719 seconds
Time Taken: 0.00169 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.12953615188599
Time Before: 0.14155 seconds
Time After: 0.14176 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.14588 seconds
Time After: 0.14862 seconds
Time Taken: 0.00274 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1788875179, location = '/forums/private.php?do=newpm&explain=1&u=28683', badlocation = 1
Time Before: 0.17059 seconds
Time After: 0.17099 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
Page generated in 0.16926717758179 seconds with 9 queries, spending 0.0097949504852295 doing MySQL queries and 0.15947222709656 doing PHP things.
