Time Before: 0.02227 seconds
Time After: 0.02747 seconds
Time Taken: 0.00519 seconds
Time Before: 0.02755 seconds
Time After: 0.02800 seconds
Time Before: 0.02823 seconds
Time After: 0.02837 seconds
Time Before: 0.02918 seconds
Time After: 0.03180 seconds
Time Taken: 0.00262 seconds
Time Before: 0.02844 seconds
Time After: 0.03577 seconds
Time Taken: 0.00734 seconds
Time Before: 0.04370 seconds
Time After: 0.04410 seconds
Time Before: 0.04572 seconds
Time After: 0.04691 seconds
Time Taken: 0.00118 seconds
Time Before: 0.04302 seconds
Time After: 0.04710 seconds
Time Taken: 0.00408 seconds
Time Before: 0.08239 seconds
Time After: 0.08253 seconds
Time Before: 0.09943 seconds
Time After: 0.10075 seconds
Time Taken: 0.00131 seconds
Time Before: 0.11032 seconds
Time After: 0.11046 seconds
Time Before: 0.11291 seconds
Time After: 0.11437 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=28738', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.13808 seconds
Time After: 0.13836 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
