Time Before: 0.00188 seconds
Time After: 0.00245 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00255 seconds
Time After: 0.00301 seconds
Time Before: 0.00327 seconds
Time After: 0.00342 seconds
Time Before: 0.00431 seconds
Time After: 0.00714 seconds
Time Taken: 0.00283 seconds
Time Before: 0.00349 seconds
Time After: 0.01246 seconds
Time Taken: 0.00897 seconds
Time Before: 0.01534 seconds
Time After: 0.01579 seconds
Time Before: 0.01847 seconds
Time After: 0.01975 seconds
Time Before: 0.01453 seconds
Time After: 0.02002 seconds
Time Taken: 0.00549 seconds
Time Before: 0.03141 seconds
Time After: 0.03156 seconds
Time Before: 0.03330 seconds
Time After: 0.03464 seconds
Time Taken: 0.00133 seconds
End call of global.php: 0.036301136016846
Time Before: 0.03743 seconds
Time After: 0.03761 seconds
Time Before: 0.03980 seconds
Time After: 0.04154 seconds
Time Taken: 0.00174 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=2894'
Time Before: 0.05744 seconds
Time After: 0.05778 seconds
Memory Before: 4,910.797 KB
Memory After: 4,911.047 KB
Memory Used: 0.250 KB
Page generated in 0.056486129760742 seconds with 9 queries, spending 0.0089054107666016 doing MySQL queries and 0.047580718994141 doing PHP things.
