Time Before: 0.01331 seconds
Time After: 0.02145 seconds
Time Taken: 0.00814 seconds
Time Before: 0.02156 seconds
Time After: 0.02200 seconds
Time Before: 0.02226 seconds
Time After: 0.02241 seconds
Time Before: 0.02319 seconds
Time After: 0.02567 seconds
Time Taken: 0.00249 seconds
Time Before: 0.02247 seconds
Time After: 0.03041 seconds
Time Taken: 0.00794 seconds
Time Before: 0.03931 seconds
Time After: 0.03975 seconds
Time Before: 0.04298 seconds
Time After: 0.04417 seconds
Time Before: 0.03845 seconds
Time After: 0.04445 seconds
Time Taken: 0.00600 seconds
Time Before: 0.08562 seconds
Time After: 0.08577 seconds
Time Before: 0.10221 seconds
Time After: 0.10345 seconds
End call of global.php: 0.10592794418335
Time Before: 0.11457 seconds
Time After: 0.11482 seconds
Time Before: 0.11743 seconds
Time After: 0.11890 seconds
SET lastactivity = 1776545922, location = '/forums/private.php?do=newpm&explain=1&u=29038'
Time Before: 0.13970 seconds
Time After: 0.14000 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.13846707344055 seconds with 9 queries, spending 0.0081169605255127 doing MySQL queries and 0.13035011291504 doing PHP things.
