Time Before: 0.00136 seconds
Time After: 0.00180 seconds
Time Before: 0.00187 seconds
Time After: 0.00261 seconds
Time Taken: 0.00074 seconds
Time Before: 0.00295 seconds
Time After: 0.00308 seconds
Time Before: 0.00378 seconds
Time After: 0.00659 seconds
Time Taken: 0.00281 seconds
Time Before: 0.00314 seconds
Time After: 0.00999 seconds
Time Taken: 0.00685 seconds
Time Before: 0.01170 seconds
Time After: 0.01208 seconds
Time Before: 0.01350 seconds
Time After: 0.01467 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01115 seconds
Time After: 0.01483 seconds
Time Taken: 0.00368 seconds
Time Before: 0.01974 seconds
Time After: 0.01991 seconds
Time Before: 0.02181 seconds
Time After: 0.02306 seconds
End call of global.php: 0.024655818939209
Time Before: 0.02595 seconds
Time After: 0.02613 seconds
Time Before: 0.02805 seconds
Time After: 0.02952 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=29088', badlocation = 1
Time Before: 0.04240 seconds
Time After: 0.12344 seconds
Time Taken: 0.08104 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.04145884513855 seconds with 9 queries, spending 0.08931827545166 doing MySQL queries and -0.04785943031311 doing PHP things.
