Time Before: 0.00951 seconds
Time After: 0.01103 seconds
Time Taken: 0.00152 seconds
Time Before: 0.01110 seconds
Time After: 0.01155 seconds
Time Before: 0.01174 seconds
Time After: 0.01185 seconds
Time Before: 0.01258 seconds
Time After: 0.01476 seconds
Time Taken: 0.00218 seconds
Time Before: 0.01190 seconds
Time After: 0.01972 seconds
Time Taken: 0.00782 seconds
Time Before: 0.02566 seconds
Time After: 0.02607 seconds
Time Before: 0.02885 seconds
Time After: 0.03012 seconds
Time Before: 0.02481 seconds
Time After: 0.03036 seconds
Time Taken: 0.00555 seconds
Time Before: 0.04695 seconds
Time After: 0.04706 seconds
Time Before: 0.09419 seconds
Time After: 0.09551 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.098387002944946
Time Before: 0.10181 seconds
Time After: 0.10196 seconds
Time Before: 0.10546 seconds
Time After: 0.10690 seconds
SET lastactivity = 1789072729, location = '/forums/private.php?do=newpm&explain=1&u=29207'
Time Before: 0.12714 seconds
Time After: 0.12755 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.12576603889465 seconds with 9 queries, spending 0.007838249206543 doing MySQL queries and 0.11792778968811 doing PHP things.
