Time Before: 0.03151 seconds
Time After: 0.04070 seconds
Time Taken: 0.00918 seconds
Time Before: 0.04079 seconds
Time After: 0.04127 seconds
Time Before: 0.04152 seconds
Time After: 0.04168 seconds
Time Before: 0.04246 seconds
Time After: 0.04534 seconds
Time Taken: 0.00288 seconds
Time Before: 0.04174 seconds
Time After: 0.05032 seconds
Time Taken: 0.00857 seconds
Time Before: 0.06022 seconds
Time After: 0.06058 seconds
Time Before: 0.06310 seconds
Time After: 0.06430 seconds
Time Before: 0.05959 seconds
Time After: 0.06451 seconds
Time Taken: 0.00491 seconds
Time Before: 0.10936 seconds
Time After: 0.10952 seconds
Time Before: 0.12913 seconds
Time After: 0.13040 seconds
End call of global.php: 0.13322997093201
Time Before: 0.14165 seconds
Time After: 0.14180 seconds
Time Before: 0.14433 seconds
Time After: 0.14589 seconds
Time Taken: 0.00156 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=29216', badlocation = 1
WHERE sessionhash = 'df28b2ca2ba03bfc49481a2edca83948'
Time Before: 0.16515 seconds
Time After: 0.16546 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.16396808624268 seconds with 9 queries, spending 0.0085384845733643 doing MySQL queries and 0.15542960166931 doing PHP things.
