Time Before: 0.01271 seconds
Time After: 0.01758 seconds
Time Taken: 0.00486 seconds
Time Before: 0.01766 seconds
Time After: 0.01838 seconds
Time Taken: 0.00072 seconds
Time Before: 0.01867 seconds
Time After: 0.01886 seconds
Time Before: 0.01959 seconds
Time After: 0.02155 seconds
Time Taken: 0.00196 seconds
Time Before: 0.01893 seconds
Time After: 0.02692 seconds
Time Taken: 0.00799 seconds
Time Before: 0.03284 seconds
Time After: 0.03320 seconds
Time Before: 0.03560 seconds
Time After: 0.03682 seconds
Time Before: 0.03216 seconds
Time After: 0.03702 seconds
Time Before: 0.05050 seconds
Time After: 0.05073 seconds
Time Before: 0.06386 seconds
Time After: 0.06512 seconds
End call of global.php: 0.067103862762451
Time Before: 0.07435 seconds
Time After: 0.07461 seconds
Time Before: 0.07709 seconds
Time After: 0.07859 seconds
Time Taken: 0.00150 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=29261'
Time Before: 0.09688 seconds
Time After: 0.09716 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.09572696685791 seconds with 9 queries, spending 0.0079736709594727 doing MySQL queries and 0.087753295898438 doing PHP things.
