Time Before: 0.00145 seconds
Time After: 0.00199 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00205 seconds
Time After: 0.00250 seconds
Time Before: 0.00276 seconds
Time After: 0.00288 seconds
Time Before: 0.00386 seconds
Time After: 0.00689 seconds
Time Taken: 0.00303 seconds
Time Before: 0.00295 seconds
Time After: 0.01201 seconds
Time Taken: 0.00905 seconds
Time Before: 0.01473 seconds
Time After: 0.01514 seconds
Time Before: 0.01813 seconds
Time After: 0.01959 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01397 seconds
Time After: 0.01987 seconds
Time Taken: 0.00590 seconds
Memory After: 2,261.836 KB
Time Before: 0.02615 seconds
Time After: 0.02634 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.02930 seconds
Time After: 0.03075 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.033559083938599
Time Before: 0.03504 seconds
Time After: 0.03524 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.03781 seconds
Time After: 0.03948 seconds
Time Taken: 0.00168 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1788969758, location = '/forums/private.php?do=newpm&explain=1&u=29362'
Time Before: 0.05300 seconds
Time After: 0.05338 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
Page generated in 0.051905155181885 seconds with 9 queries, spending 0.0093810558319092 doing MySQL queries and 0.042524099349976 doing PHP things.
