Time Before: 0.02617 seconds
Time After: 0.03517 seconds
Time Taken: 0.00900 seconds
Time Before: 0.03527 seconds
Time After: 0.03565 seconds
Time Before: 0.03588 seconds
Time After: 0.03607 seconds
Time Before: 0.03681 seconds
Time After: 0.04009 seconds
Time Taken: 0.00328 seconds
Time Before: 0.03615 seconds
Time After: 0.04568 seconds
Time Taken: 0.00953 seconds
Time Before: 0.05434 seconds
Time After: 0.05478 seconds
Time Before: 0.05666 seconds
Time After: 0.05793 seconds
Time Before: 0.05351 seconds
Time After: 0.05815 seconds
Time Taken: 0.00464 seconds
Time Before: 0.10726 seconds
Time After: 0.10743 seconds
Time Before: 0.12505 seconds
Time After: 0.12632 seconds
Time Before: 0.13951 seconds
Time After: 0.13967 seconds
Time Before: 0.14207 seconds
Time After: 0.14353 seconds
UPDATE session SET lastactivity = 1785399862, location = '/forums/private.php?do=newpm&explain=1&u=29396' WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.16756 seconds
Time After: 0.16791 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
