Time Before: 0.01751 seconds
Time After: 0.02192 seconds
Time Taken: 0.00440 seconds
Time Before: 0.02201 seconds
Time After: 0.02245 seconds
Time Before: 0.02267 seconds
Time After: 0.02299 seconds
Time Before: 0.02408 seconds
Time After: 0.02641 seconds
Time Taken: 0.00232 seconds
Time Before: 0.02307 seconds
Time After: 0.03079 seconds
Time Taken: 0.00772 seconds
Time Before: 0.03680 seconds
Time After: 0.03700 seconds
Time Before: 0.03851 seconds
Time After: 0.03970 seconds
Time Before: 0.03602 seconds
Time After: 0.03991 seconds
Time Taken: 0.00389 seconds
Time Before: 0.06914 seconds
Time After: 0.06948 seconds
Time Before: 0.08433 seconds
Time After: 0.08555 seconds
End call of global.php: 0.088582992553711
Time Before: 0.09510 seconds
Time After: 0.09526 seconds
Time Before: 0.09778 seconds
Time After: 0.09939 seconds
Time Taken: 0.00161 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=29414', badlocation = 1
Time Before: 0.11827 seconds
Time After: 0.11863 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.11727595329285 seconds with 9 queries, spending 0.0081791877746582 doing MySQL queries and 0.10909676551819 doing PHP things.
