Time Before: 0.02643 seconds
Time After: 0.03383 seconds
Time Taken: 0.00740 seconds
Time Before: 0.03392 seconds
Time After: 0.03438 seconds
Time Before: 0.03457 seconds
Time After: 0.03475 seconds
Time Before: 0.03545 seconds
Time After: 0.03774 seconds
Time Taken: 0.00229 seconds
Time Before: 0.03482 seconds
Time After: 0.04213 seconds
Time Taken: 0.00732 seconds
Time Before: 0.05138 seconds
Time After: 0.05193 seconds
Time Taken: 0.00055 seconds
Time Before: 0.05524 seconds
Time After: 0.05642 seconds
Time Taken: 0.00118 seconds
Time Before: 0.05066 seconds
Time After: 0.05664 seconds
Time Taken: 0.00598 seconds
Time Before: 0.10866 seconds
Time After: 0.10892 seconds
Time Before: 0.13019 seconds
Time After: 0.13144 seconds
Time Before: 0.14380 seconds
Time After: 0.14403 seconds
Time Before: 0.14708 seconds
Time After: 0.14855 seconds
UPDATE session SET lastactivity = 1776478082, location = '/forums/private.php?do=newpm&explain=1&u=29522', badlocation = 1 WHERE sessionhash = '0d59333b9979c57800f17621ab8164fa'
Time Before: 0.16849 seconds
Time After: 0.16887 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
