Time Before: 0.00785 seconds
Time After: 0.01057 seconds
Time Taken: 0.00272 seconds
Time Before: 0.01068 seconds
Time After: 0.01114 seconds
Time Before: 0.01142 seconds
Time After: 0.01154 seconds
Time Before: 0.01245 seconds
Time After: 0.01465 seconds
Time Taken: 0.00219 seconds
Time Before: 0.01161 seconds
Time After: 0.02020 seconds
Time Taken: 0.00859 seconds
Time Before: 0.02478 seconds
Time After: 0.02524 seconds
Time Before: 0.02687 seconds
Time After: 0.02809 seconds
Time Before: 0.02392 seconds
Time After: 0.02834 seconds
Time Taken: 0.00443 seconds
Time Before: 0.05666 seconds
Time After: 0.05682 seconds
Time Before: 0.06884 seconds
Time After: 0.07027 seconds
End call of global.php: 0.072211980819702
Time Before: 0.07721 seconds
Time After: 0.07738 seconds
Time Before: 0.07994 seconds
Time After: 0.08141 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=29625'
Time Before: 0.10014 seconds
Time After: 0.10057 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.098994016647339 seconds with 9 queries, spending 0.0081260204315186 doing MySQL queries and 0.09086799621582 doing PHP things.
