Time Before: 0.00203 seconds
Time After: 0.00262 seconds
Time Taken: 0.00059 seconds
Memory Before: 533.906 KB
Memory After: 559.023 KB
Time Before: 0.00272 seconds
Time After: 0.00322 seconds
Memory Before: 558.961 KB
Memory After: 559.969 KB
Time Before: 0.00352 seconds
Time After: 0.00365 seconds
Memory Before: 560.523 KB
Memory After: 561.047 KB
Time Before: 0.00450 seconds
Time After: 0.00801 seconds
Time Taken: 0.00351 seconds
Memory Before: 563.648 KB
Memory After: 564.570 KB
Time Before: 0.00372 seconds
Time After: 0.01148 seconds
Time Taken: 0.00776 seconds
Memory Before: 560.297 KB
Memory After: 1,641.297 KB
Memory Used: 1,081.000 KB
Time Before: 0.01396 seconds
Time After: 0.01455 seconds
Memory Before: 2,136.141 KB
Memory After: 2,136.758 KB
Time Before: 0.01730 seconds
Time After: 0.01853 seconds
Memory Before: 2,148.320 KB
Memory After: 2,148.180 KB
Time Before: 0.01315 seconds
Time After: 0.01871 seconds
Time Taken: 0.00557 seconds
Memory Before: 2,128.320 KB
Memory After: 2,261.203 KB
Time Before: 0.02476 seconds
Time After: 0.02490 seconds
Memory Before: 2,814.781 KB
Memory After: 2,815.297 KB
Time Before: 0.02734 seconds
Time After: 0.02873 seconds
Time Taken: 0.00140 seconds
Memory Before: 2,903.117 KB
Memory After: 2,903.711 KB
End call of global.php: 0.030419111251831
Time Before: 0.03240 seconds
Time After: 0.03263 seconds
Memory Before: 3,539.836 KB
Memory After: 3,540.266 KB
Time Before: 0.03549 seconds
Time After: 0.03699 seconds
Time Taken: 0.00150 seconds
Memory Before: 3,821.367 KB
Memory After: 3,823.055 KB
SET lastactivity = 1788886748, location = '/forums/private.php?do=newpm&explain=1&u=2970'
Time Before: 0.05240 seconds
Time After: 0.05283 seconds
Memory Before: 4,295.195 KB
Memory After: 4,295.414 KB
Page generated in 0.051482915878296 seconds with 9 queries, spending 0.0096530914306641 doing MySQL queries and 0.041829824447632 doing PHP things.
