Time Before: 0.00202 seconds
Time After: 0.00365 seconds
Time Taken: 0.00164 seconds
Time Before: 0.00376 seconds
Time After: 0.00422 seconds
Time Before: 0.00444 seconds
Time After: 0.00456 seconds
Time Before: 0.00529 seconds
Time After: 0.00971 seconds
Time Taken: 0.00441 seconds
Time Before: 0.00461 seconds
Time After: 0.01417 seconds
Time Taken: 0.00956 seconds
Time Before: 0.01850 seconds
Time After: 0.01887 seconds
Time Before: 0.02144 seconds
Time After: 0.02273 seconds
Time Before: 0.01749 seconds
Time After: 0.02290 seconds
Time Taken: 0.00541 seconds
Time Before: 0.03411 seconds
Time After: 0.03425 seconds
Time Before: 0.03832 seconds
Time After: 0.03960 seconds
End call of global.php: 0.041209936141968
Time Before: 0.04356 seconds
Time After: 0.04391 seconds
Time Before: 0.04591 seconds
Time After: 0.04742 seconds
Time Taken: 0.00151 seconds
SET lastactivity = 1783414848, location = '/forums/private.php?do=newpm&explain=1&u=29718', badlocation = 1
WHERE sessionhash = '785a5ccc852039ad054a2e3a39163c15'
Time Before: 0.06025 seconds
Time After: 0.06101 seconds
Time Taken: 0.00076 seconds
Memory Before: 4,912.227 KB
Memory After: 4,912.438 KB
Page generated in 0.059355020523071 seconds with 9 queries, spending 0.010670185089111 doing MySQL queries and 0.04868483543396 doing PHP things.
