Time Before: 0.00713 seconds
Time After: 0.01159 seconds
Time Taken: 0.00446 seconds
Time Before: 0.01170 seconds
Time After: 0.01214 seconds
Time Before: 0.01239 seconds
Time After: 0.01254 seconds
Time Before: 0.01337 seconds
Time After: 0.01589 seconds
Time Taken: 0.00252 seconds
Time Before: 0.01262 seconds
Time After: 0.02041 seconds
Time Taken: 0.00779 seconds
Time Before: 0.02460 seconds
Time After: 0.02500 seconds
Time Before: 0.02735 seconds
Time After: 0.02854 seconds
Time Before: 0.02387 seconds
Time After: 0.02871 seconds
Time Taken: 0.00484 seconds
Time Before: 0.04134 seconds
Time After: 0.04150 seconds
Time Before: 0.04916 seconds
Time After: 0.05041 seconds
End call of global.php: 0.052463054656982
Time Before: 0.05696 seconds
Time After: 0.05711 seconds
Time Before: 0.05995 seconds
Time After: 0.06139 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=29751', badlocation = 1
Time Before: 0.07733 seconds
Time After: 0.07766 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.076271057128906 seconds with 9 queries, spending 0.0080087184906006 doing MySQL queries and 0.068262338638306 doing PHP things.
