Time Before: 0.00144 seconds
Time After: 0.00193 seconds
Time Before: 0.00200 seconds
Time After: 0.00273 seconds
Time Taken: 0.00073 seconds
Time Before: 0.00306 seconds
Time After: 0.00321 seconds
Time Before: 0.00396 seconds
Time After: 0.00629 seconds
Time Taken: 0.00233 seconds
Time Before: 0.00326 seconds
Time After: 0.01112 seconds
Time Taken: 0.00786 seconds
Time Before: 0.01335 seconds
Time After: 0.01383 seconds
Time Before: 0.01617 seconds
Time After: 0.01742 seconds
Time Before: 0.01260 seconds
Time After: 0.01759 seconds
Time Taken: 0.00499 seconds
Time Before: 0.02290 seconds
Time After: 0.02306 seconds
Time Before: 0.02525 seconds
Time After: 0.02659 seconds
Time Taken: 0.00133 seconds
End call of global.php: 0.028204917907715
Time Before: 0.02937 seconds
Time After: 0.02952 seconds
Time Before: 0.03146 seconds
Time After: 0.03293 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=29828', badlocation = 1
WHERE sessionhash = 'cf9a7d249f143a0ae3eb7b561aa7a27f'
Time Before: 0.04540 seconds
Time After: 0.04590 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.044313907623291 seconds with 9 queries, spending 0.008554220199585 doing MySQL queries and 0.035759687423706 doing PHP things.
