Time Before: 0.00221 seconds
Time After: 0.00279 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00289 seconds
Time After: 0.00343 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00364 seconds
Time After: 0.00378 seconds
Time Before: 0.00465 seconds
Time After: 0.00739 seconds
Time Taken: 0.00274 seconds
Time Before: 0.00383 seconds
Time After: 0.01079 seconds
Time Taken: 0.00696 seconds
Time Before: 0.01270 seconds
Time After: 0.01306 seconds
Time Before: 0.01446 seconds
Time After: 0.01568 seconds
Time Before: 0.01206 seconds
Time After: 0.01585 seconds
Time Taken: 0.00379 seconds
Time Before: 0.02071 seconds
Time After: 0.02085 seconds
Time Before: 0.02269 seconds
Time After: 0.02398 seconds
End call of global.php: 0.025604009628296
Time Before: 0.02702 seconds
Time After: 0.02731 seconds
Time Before: 0.02954 seconds
Time After: 0.03099 seconds
SET lastactivity = 1785399900, location = '/forums/private.php?do=newpm&explain=1&u=29960', badlocation = 1
Time Before: 0.04320 seconds
Time After: 0.04349 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.042304992675781 seconds with 9 queries, spending 0.0084671974182129 doing MySQL queries and 0.033837795257568 doing PHP things.
