Time Before: 0.02125 seconds
Time After: 0.02948 seconds
Time Taken: 0.00824 seconds
Time Before: 0.02959 seconds
Time After: 0.03016 seconds
Time Taken: 0.00057 seconds
Time Before: 0.03038 seconds
Time After: 0.03049 seconds
Time Before: 0.03127 seconds
Time After: 0.03368 seconds
Time Taken: 0.00241 seconds
Time Before: 0.03054 seconds
Time After: 0.03773 seconds
Time Taken: 0.00719 seconds
Time Before: 0.04516 seconds
Time After: 0.04554 seconds
Time Before: 0.04825 seconds
Time After: 0.04983 seconds
Time Taken: 0.00158 seconds
Time Before: 0.04440 seconds
Time After: 0.05007 seconds
Time Taken: 0.00567 seconds
Time Before: 0.07770 seconds
Time After: 0.07785 seconds
Time Before: 1.47378 seconds
Time After: 1.47577 seconds
Time Taken: 0.00199 seconds
Time Before: 1.48494 seconds
Time After: 1.48509 seconds
Time Before: 1.48726 seconds
Time After: 1.48889 seconds
Time Taken: 0.00163 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=29995', badlocation = 1 WHERE sessionhash = '0d59333b9979c57800f17621ab8164fa'
Time Before: 1.50771 seconds
Time After: 1.50797 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
