Time Before: 0.02535 seconds
Time After: 0.02985 seconds
Time Taken: 0.00450 seconds
Time Before: 0.02996 seconds
Time After: 0.03038 seconds
Time Before: 0.03063 seconds
Time After: 0.03079 seconds
Time Before: 0.03156 seconds
Time After: 0.03455 seconds
Time Taken: 0.00299 seconds
Time Before: 0.03085 seconds
Time After: 0.03868 seconds
Time Taken: 0.00783 seconds
Time Before: 0.04777 seconds
Time After: 0.04819 seconds
Time Before: 0.05054 seconds
Time After: 0.05178 seconds
Time Before: 0.04700 seconds
Time After: 0.05195 seconds
Time Taken: 0.00495 seconds
Time Before: 0.07983 seconds
Time After: 0.07996 seconds
Time Before: 0.10394 seconds
Time After: 0.10523 seconds
Time Before: 0.11683 seconds
Time After: 0.11747 seconds
Time Taken: 0.00063 seconds
Time Before: 0.12017 seconds
Time After: 0.12179 seconds
Time Taken: 0.00162 seconds
UPDATE session SET lastactivity = 1776615249, location = '/forums/private.php?do=newpm&explain=1&u=30015', badlocation = 1 WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.14614 seconds
Time After: 0.14648 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
