Time Before: 0.03084 seconds
Time After: 0.03859 seconds
Time Taken: 0.00775 seconds
Time Before: 0.03868 seconds
Time After: 0.03908 seconds
Time Before: 0.03929 seconds
Time After: 0.03944 seconds
Time Before: 0.04018 seconds
Time After: 0.04232 seconds
Time Taken: 0.00214 seconds
Time Before: 0.03951 seconds
Time After: 0.04615 seconds
Time Taken: 0.00664 seconds
Time Before: 0.05317 seconds
Time After: 0.05358 seconds
Time Before: 0.05666 seconds
Time After: 0.05787 seconds
Time Before: 0.05255 seconds
Time After: 0.05812 seconds
Time Taken: 0.00556 seconds
Time Before: 0.11884 seconds
Time After: 0.11899 seconds
Time Before: 0.13595 seconds
Time After: 0.13728 seconds
Time Taken: 0.00133 seconds
Time Before: 0.14764 seconds
Time After: 0.14782 seconds
Time Before: 0.15080 seconds
Time After: 0.15231 seconds
Time Taken: 0.00151 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=30030' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.17404 seconds
Time After: 0.17426 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
