Time Before: 0.01469 seconds
Time After: 0.02180 seconds
Time Taken: 0.00710 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.02193 seconds
Time After: 0.02235 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02257 seconds
Time After: 0.02269 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02348 seconds
Time After: 0.02603 seconds
Time Taken: 0.00254 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02277 seconds
Time After: 0.03031 seconds
Time Taken: 0.00754 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.03946 seconds
Time After: 0.03990 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04250 seconds
Time After: 0.04365 seconds
Time Taken: 0.00115 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.03862 seconds
Time After: 0.04391 seconds
Time Taken: 0.00529 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.07617 seconds
Time After: 0.07629 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.11298 seconds
Time After: 0.11419 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
End call of global.php: 0.11609792709351
Time Before: 0.13111 seconds
Time After: 0.13125 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.13505 seconds
Time After: 0.13645 seconds
Time Taken: 0.00140 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=30063', badlocation = 1
Time Before: 0.15957 seconds
Time After: 0.15985 seconds
Memory Before: 5,997.742 KB
Memory After: 5,997.961 KB
Page generated in 0.1585648059845 seconds with 9 queries, spending 0.0078275203704834 doing MySQL queries and 0.15073728561401 doing PHP things.
