Time Before: 0.00214 seconds
Time After: 0.00326 seconds
Time Taken: 0.00113 seconds
Time Before: 0.00333 seconds
Time After: 0.00372 seconds
Time Before: 0.00394 seconds
Time After: 0.00407 seconds
Time Before: 0.00479 seconds
Time After: 0.00778 seconds
Time Taken: 0.00299 seconds
Time Before: 0.00412 seconds
Time After: 0.01129 seconds
Time Taken: 0.00717 seconds
Time Before: 0.01316 seconds
Time After: 0.01360 seconds
Time Before: 0.01509 seconds
Time After: 0.01638 seconds
Time Before: 0.01254 seconds
Time After: 0.01656 seconds
Time Taken: 0.00402 seconds
Time Before: 0.02195 seconds
Time After: 0.02211 seconds
Time Before: 0.02436 seconds
Time After: 0.02590 seconds
Time Taken: 0.00153 seconds
End call of global.php: 0.027557849884033
Time Before: 0.02908 seconds
Time After: 0.02924 seconds
Time Before: 0.03136 seconds
Time After: 0.03284 seconds
SET lastactivity = 1776716572, location = '/forums/private.php?do=newpm&explain=1&u=30080'
Time Before: 0.04857 seconds
Time After: 0.04896 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.047175884246826 seconds with 9 queries, spending 0.008967399597168 doing MySQL queries and 0.038208484649658 doing PHP things.
