Time Before: 0.00139 seconds
Time After: 0.00196 seconds
Time Taken: 0.00057 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00204 seconds
Time After: 0.00237 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00260 seconds
Time After: 0.00279 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00358 seconds
Time After: 0.00608 seconds
Time Taken: 0.00251 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00286 seconds
Time After: 0.01018 seconds
Time Taken: 0.00732 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.766 KB
Time Before: 0.01257 seconds
Time After: 0.01304 seconds
Memory Before: 2,759.469 KB
Memory After: 2,760.086 KB
Time Before: 0.01612 seconds
Time After: 0.01754 seconds
Memory Before: 2,771.523 KB
Memory After: 2,771.383 KB
Time Before: 0.01180 seconds
Time After: 0.01778 seconds
Time Taken: 0.00598 seconds
Memory Before: 2,751.609 KB
Memory After: 2,884.414 KB
Time Before: 0.02293 seconds
Time After: 0.02312 seconds
Memory Before: 3,437.547 KB
Memory After: 3,438.063 KB
Time Before: 0.02492 seconds
Time After: 0.02612 seconds
Memory Before: 3,525.344 KB
Memory After: 3,525.938 KB
End call of global.php: 0.027834892272949
Time Before: 0.02910 seconds
Time After: 0.02924 seconds
Memory Before: 4,163.203 KB
Memory After: 4,163.633 KB
Time Before: 0.03131 seconds
Time After: 0.03273 seconds
Memory Before: 4,444.766 KB
Memory After: 4,446.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=30165'
Time Before: 0.04531 seconds
Time After: 0.04567 seconds
Memory Before: 4,918.352 KB
Memory After: 4,918.594 KB
Page generated in 0.044438123703003 seconds with 9 queries, spending 0.0082111358642578 doing MySQL queries and 0.036226987838745 doing PHP things.
