Time Before: 0.01656 seconds
Time After: 0.02675 seconds
Time Taken: 0.01019 seconds
Time Before: 0.02687 seconds
Time After: 0.02733 seconds
Time Before: 0.02762 seconds
Time After: 0.02777 seconds
Time Before: 0.02859 seconds
Time After: 0.03224 seconds
Time Taken: 0.00365 seconds
Time Before: 0.02784 seconds
Time After: 0.03697 seconds
Time Taken: 0.00912 seconds
Time Before: 0.04738 seconds
Time After: 0.04790 seconds
Time Before: 0.05047 seconds
Time After: 0.05173 seconds
Time Before: 0.04663 seconds
Time After: 0.05194 seconds
Time Taken: 0.00532 seconds
Time Before: 0.09027 seconds
Time After: 0.09042 seconds
Time Before: 0.10976 seconds
Time After: 0.11111 seconds
Time Taken: 0.00135 seconds
Time Before: 0.12175 seconds
Time After: 0.12201 seconds
Time Before: 0.12448 seconds
Time After: 0.12624 seconds
Time Taken: 0.00176 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=30426', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.14539 seconds
Time After: 0.14567 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
