Time Before: 0.00259 seconds
Time After: 0.00450 seconds
Time Taken: 0.00190 seconds
Time Before: 0.00465 seconds
Time After: 0.00515 seconds
Time Before: 0.00543 seconds
Time After: 0.00556 seconds
Time Before: 0.00654 seconds
Time After: 0.00911 seconds
Time Taken: 0.00257 seconds
Time Before: 0.00564 seconds
Time After: 0.01394 seconds
Time Taken: 0.00830 seconds
Time Before: 0.01651 seconds
Time After: 0.01692 seconds
Time Before: 0.01975 seconds
Time After: 0.02099 seconds
Time Before: 0.01566 seconds
Time After: 0.02126 seconds
Time Taken: 0.00561 seconds
Time Before: 0.02872 seconds
Time After: 0.02886 seconds
Time Before: 0.03235 seconds
Time After: 0.03359 seconds
End call of global.php: 0.036597013473511
Time Before: 0.03849 seconds
Time After: 0.03865 seconds
Time Before: 0.04137 seconds
Time After: 0.04283 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=30442', badlocation = 1
Time Before: 0.05872 seconds
Time After: 0.05910 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.057537078857422 seconds with 9 queries, spending 0.0082237720489502 doing MySQL queries and 0.049313306808472 doing PHP things.
