Time Before: 0.00132 seconds
Time After: 0.00193 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00201 seconds
Time After: 0.00243 seconds
Time Before: 0.00267 seconds
Time After: 0.00280 seconds
Time Before: 0.00366 seconds
Time After: 0.00599 seconds
Time Taken: 0.00233 seconds
Time Before: 0.00288 seconds
Time After: 0.01070 seconds
Time Taken: 0.00782 seconds
Time Before: 0.01322 seconds
Time After: 0.01364 seconds
Time Before: 0.01607 seconds
Time After: 0.01727 seconds
Time Before: 0.01255 seconds
Time After: 0.01746 seconds
Time Taken: 0.00491 seconds
Time Before: 0.02261 seconds
Time After: 0.02275 seconds
Time Before: 0.02456 seconds
Time After: 0.02577 seconds
End call of global.php: 0.027506113052368
Time Before: 0.02866 seconds
Time After: 0.02879 seconds
Time Before: 0.03089 seconds
Time After: 0.03230 seconds
SET lastactivity = 1788872999, location = '/forums/private.php?do=newpm&explain=1&u=30445'
Time Before: 0.04657 seconds
Time After: 0.04688 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.045639991760254 seconds with 9 queries, spending 0.0077011585235596 doing MySQL queries and 0.037938833236694 doing PHP things.
