Time Before: 0.00157 seconds
Time After: 0.00202 seconds
Time Before: 0.00209 seconds
Time After: 0.00254 seconds
Time Before: 0.00278 seconds
Time After: 0.00292 seconds
Time Before: 0.00375 seconds
Time After: 0.00651 seconds
Time Taken: 0.00277 seconds
Time Before: 0.00300 seconds
Time After: 0.01072 seconds
Time Taken: 0.00772 seconds
Time Before: 0.01303 seconds
Time After: 0.01351 seconds
Time Before: 0.01619 seconds
Time After: 0.01747 seconds
Time Before: 0.01215 seconds
Time After: 0.01774 seconds
Time Taken: 0.00559 seconds
Time Before: 0.02405 seconds
Time After: 0.02442 seconds
Time Before: 0.02627 seconds
Time After: 0.02750 seconds
End call of global.php: 0.029536962509155
Time Before: 0.03121 seconds
Time After: 0.03137 seconds
Time Before: 0.03427 seconds
Time After: 0.03584 seconds
Time Taken: 0.00156 seconds
SET lastactivity = 1788897247, location = '/forums/private.php?do=newpm&explain=1&u=30466'
Time Before: 0.05190 seconds
Time After: 0.05261 seconds
Time Taken: 0.00072 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.050976991653442 seconds with 9 queries, spending 0.0091478824615479 doing MySQL queries and 0.041829109191895 doing PHP things.
