Time Before: 0.01474 seconds
Time After: 0.01823 seconds
Time Taken: 0.00348 seconds
Time Before: 0.01831 seconds
Time After: 0.01875 seconds
Time Before: 0.01897 seconds
Time After: 0.01911 seconds
Time Before: 0.01995 seconds
Time After: 0.02242 seconds
Time Taken: 0.00247 seconds
Time Before: 0.01916 seconds
Time After: 0.02682 seconds
Time Taken: 0.00766 seconds
Time Before: 0.03248 seconds
Time After: 0.03293 seconds
Time Before: 0.03624 seconds
Time After: 0.03770 seconds
Time Before: 0.03172 seconds
Time After: 0.03794 seconds
Time Taken: 0.00623 seconds
Time Before: 0.05936 seconds
Time After: 0.05951 seconds
Time Before: 0.06952 seconds
Time After: 0.07078 seconds
End call of global.php: 0.073200941085815
Time Before: 0.07794 seconds
Time After: 0.07809 seconds
Time Before: 0.08057 seconds
Time After: 0.08203 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=30495'
Time Before: 0.09888 seconds
Time After: 0.09922 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.097743988037109 seconds with 9 queries, spending 0.0083053112030029 doing MySQL queries and 0.089438676834106 doing PHP things.
