Time Before: 0.01290 seconds
Time After: 0.01578 seconds
Time Taken: 0.00289 seconds
Time Before: 0.01590 seconds
Time After: 0.01634 seconds
Time Before: 0.01658 seconds
Time After: 0.01682 seconds
Time Before: 0.01759 seconds
Time After: 0.02087 seconds
Time Taken: 0.00328 seconds
Time Before: 0.01688 seconds
Time After: 0.02572 seconds
Time Taken: 0.00884 seconds
Time Before: 0.02992 seconds
Time After: 0.03030 seconds
Time Before: 0.03321 seconds
Time After: 0.03463 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.02927 seconds
Time After: 0.03488 seconds
Time Taken: 0.00562 seconds
Memory After: 2,261.836 KB
Time Before: 0.04839 seconds
Time After: 0.04858 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.06193 seconds
Time After: 0.06371 seconds
Time Taken: 0.00179 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.07069 seconds
Time After: 0.07084 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.07345 seconds
Time After: 0.07506 seconds
Time Taken: 0.00161 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1789129669, location = '/forums/private.php?do=newpm&explain=1&u=30689', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.09213 seconds
Time After: 0.09238 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
