Time Before: 0.00179 seconds
Time After: 0.00246 seconds
Time Taken: 0.00067 seconds
Time Before: 0.00256 seconds
Time After: 0.00309 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00338 seconds
Time After: 0.00359 seconds
Time Before: 0.00452 seconds
Time After: 0.00702 seconds
Time Taken: 0.00250 seconds
Time Before: 0.00367 seconds
Time After: 0.01260 seconds
Time Taken: 0.00892 seconds
Time Before: 0.01485 seconds
Time After: 0.01527 seconds
Time Before: 0.01885 seconds
Time After: 0.02053 seconds
Time Taken: 0.00168 seconds
Time Before: 0.01417 seconds
Time After: 0.02081 seconds
Time Taken: 0.00664 seconds
Time Before: 0.02775 seconds
Time After: 0.02796 seconds
Time Before: 0.02987 seconds
Time After: 0.03111 seconds
End call of global.php: 0.032817125320435
Time Before: 0.03413 seconds
Time After: 0.03437 seconds
Time Before: 0.03667 seconds
Time After: 0.03819 seconds
Time Taken: 0.00151 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=30823', badlocation = 1
WHERE sessionhash = '600503b925d08d481e162d46884ab830'
Time Before: 0.05305 seconds
Time After: 0.05343 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.052098989486694 seconds with 9 queries, spending 0.0089259147644043 doing MySQL queries and 0.04317307472229 doing PHP things.
