Time Before: 0.02672 seconds
Time After: 0.03767 seconds
Time Taken: 0.01095 seconds
Time Before: 0.03776 seconds
Time After: 0.03999 seconds
Time Taken: 0.00223 seconds
Time Before: 0.04028 seconds
Time After: 0.04041 seconds
Time Before: 0.04138 seconds
Time After: 0.04412 seconds
Time Taken: 0.00274 seconds
Time Before: 0.04049 seconds
Time After: 0.04892 seconds
Time Taken: 0.00843 seconds
Time Before: 0.05696 seconds
Time After: 0.05794 seconds
Time Taken: 0.00098 seconds
Time Before: 0.06171 seconds
Time After: 0.06291 seconds
Time Before: 0.05608 seconds
Time After: 0.06310 seconds
Time Taken: 0.00701 seconds
Time Before: 0.10355 seconds
Time After: 0.10369 seconds
Time Before: 0.12034 seconds
Time After: 0.12157 seconds
End call of global.php: 0.12385392189026
Time Before: 0.13284 seconds
Time After: 0.13314 seconds
Time Before: 0.13619 seconds
Time After: 0.13770 seconds
Time Taken: 0.00150 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=30881', badlocation = 1
WHERE sessionhash = '7775e95b18bef93607bc556467059588'
Time Before: 0.15541 seconds
Time After: 0.15572 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.154452085495 seconds with 9 queries, spending 0.010771751403809 doing MySQL queries and 0.14368033409119 doing PHP things.
