Time Before: 0.00997 seconds
Time After: 0.01245 seconds
Time Taken: 0.00248 seconds
Time Before: 0.01256 seconds
Time After: 0.01304 seconds
Time Before: 0.01336 seconds
Time After: 0.01348 seconds
Time Before: 0.01419 seconds
Time After: 0.01667 seconds
Time Before: 0.01353 seconds
Time After: 0.02108 seconds
Time Taken: 0.00755 seconds
Time Before: 0.02503 seconds
Time After: 0.02539 seconds
Time Before: 0.02778 seconds
Time After: 0.02899 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.02435 seconds
Time After: 0.02916 seconds
Time Taken: 0.00481 seconds
Memory After: 2,261.719 KB
Time Before: 0.04020 seconds
Time After: 0.04033 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.04678 seconds
Time After: 0.04800 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.05424 seconds
Time After: 0.05491 seconds
Time Taken: 0.00067 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.05736 seconds
Time After: 0.05881 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=30971' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.07255 seconds
Time After: 0.07281 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
