Time Before: 0.00202 seconds
Time After: 0.00270 seconds
Time Taken: 0.00067 seconds
Time Before: 0.00280 seconds
Time After: 0.00330 seconds
Time Before: 0.00354 seconds
Time After: 0.00369 seconds
Time Before: 0.00458 seconds
Time After: 0.00701 seconds
Time Taken: 0.00243 seconds
Time Before: 0.00378 seconds
Time After: 0.01234 seconds
Time Taken: 0.00856 seconds
Time Before: 0.01559 seconds
Time After: 0.01598 seconds
Time Before: 0.01876 seconds
Time After: 0.01999 seconds
Time Before: 0.01473 seconds
Time After: 0.02026 seconds
Time Taken: 0.00553 seconds
Time Before: 0.03064 seconds
Time After: 0.03081 seconds
Time Before: 0.03473 seconds
Time After: 0.03598 seconds
End call of global.php: 0.038683891296387
Time Before: 0.04003 seconds
Time After: 0.04020 seconds
Time Before: 0.04331 seconds
Time After: 0.04492 seconds
Time Taken: 0.00161 seconds
SET lastactivity = 1783282193, location = '/forums/private.php?do=newpm&explain=1&u=30977', badlocation = 1
Time Before: 0.06467 seconds
Time After: 0.06507 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.06341290473938 seconds with 9 queries, spending 0.0083017349243164 doing MySQL queries and 0.055111169815063 doing PHP things.
