Time Before: 0.02022 seconds
Time After: 0.02561 seconds
Time Taken: 0.00539 seconds
Time Before: 0.02569 seconds
Time After: 0.02609 seconds
Time Before: 0.02633 seconds
Time After: 0.02648 seconds
Time Before: 0.02727 seconds
Time After: 0.02969 seconds
Time Taken: 0.00242 seconds
Time Before: 0.02654 seconds
Time After: 0.03503 seconds
Time Taken: 0.00849 seconds
Time Before: 0.04107 seconds
Time After: 0.04147 seconds
Time Before: 0.04283 seconds
Time After: 0.04401 seconds
Time Taken: 0.00118 seconds
Time Before: 0.04029 seconds
Time After: 0.04419 seconds
Time Taken: 0.00390 seconds
Time Before: 0.06253 seconds
Time After: 0.06270 seconds
Time Before: 0.07332 seconds
Time After: 0.07455 seconds
End call of global.php: 0.076655149459839
Time Before: 0.08303 seconds
Time After: 0.08319 seconds
Time Before: 0.08574 seconds
Time After: 0.08727 seconds
Time Taken: 0.00153 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=30983', badlocation = 1
Time Before: 0.10255 seconds
Time After: 0.10281 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.10162210464478 seconds with 9 queries, spending 0.0079085826873779 doing MySQL queries and 0.093713521957397 doing PHP things.
