Time Before: 0.02116 seconds
Time After: 0.02634 seconds
Time Taken: 0.00518 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.02644 seconds
Time After: 0.02691 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02718 seconds
Time After: 0.02730 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02816 seconds
Time After: 0.03116 seconds
Time Taken: 0.00300 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02737 seconds
Time After: 0.03662 seconds
Time Taken: 0.00924 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.04381 seconds
Time After: 0.04427 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04738 seconds
Time After: 0.04859 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.04287 seconds
Time After: 0.04887 seconds
Time Taken: 0.00600 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.07811 seconds
Time After: 0.07829 seconds
Memory Before: 3,655.680 KB
Memory After: 3,656.195 KB
Time Before: 0.10883 seconds
Time After: 0.11009 seconds
Memory Before: 4,133.273 KB
Memory After: 4,133.867 KB
End call of global.php: 0.11235189437866
Time Before: 0.13319 seconds
Time After: 0.13334 seconds
Memory Before: 5,197.516 KB
Memory After: 5,325.859 KB
Time Before: 0.13874 seconds
Time After: 0.14029 seconds
Time Taken: 0.00155 seconds
Memory Before: 5,481.203 KB
Memory After: 5,610.805 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=30984', badlocation = 1
WHERE sessionhash = '4107984102e2914075bf6bfb65da9afe'
Time Before: 0.16219 seconds
Time After: 0.16263 seconds
Memory Before: 5,997.742 KB
Memory After: 5,997.969 KB
Page generated in 0.16117811203003 seconds with 9 queries, spending 0.0088491439819336 doing MySQL queries and 0.1523289680481 doing PHP things.
