Time Before: 0.02390 seconds
Time After: 0.02966 seconds
Time Taken: 0.00576 seconds
Time Before: 0.02978 seconds
Time After: 0.03048 seconds
Time Taken: 0.00070 seconds
Time Before: 0.03080 seconds
Time After: 0.03097 seconds
Time Before: 0.03196 seconds
Time After: 0.03524 seconds
Time Taken: 0.00328 seconds
Time Before: 0.03112 seconds
Time After: 0.03979 seconds
Time Taken: 0.00867 seconds
Time Before: 0.04788 seconds
Time After: 0.04835 seconds
Time Before: 0.05156 seconds
Time After: 0.05277 seconds
Time Before: 0.04720 seconds
Time After: 0.05296 seconds
Time Before: 0.09771 seconds
Time After: 0.09784 seconds
Time Before: 0.11486 seconds
Time After: 0.11623 seconds
Time Taken: 0.00137 seconds
End call of global.php: 0.11842584609985
Time Before: 0.12563 seconds
Time After: 0.12583 seconds
Time Before: 0.12926 seconds
Time After: 0.13073 seconds
SET lastactivity = 1782937942, location = '/forums/private.php?do=newpm&explain=1&u=31103', badlocation = 1
Time Before: 0.14984 seconds
Time After: 0.15010 seconds
Memory Before: 4,912.227 KB
Memory After: 4,912.438 KB
Page generated in 0.14877891540527 seconds with 9 queries, spending 0.0092625617980957 doing MySQL queries and 0.13951635360718 doing PHP things.
