Time Before: 0.00144 seconds
Time After: 0.00203 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00210 seconds
Time After: 0.00256 seconds
Time Before: 0.00281 seconds
Time After: 0.00294 seconds
Time Before: 0.00387 seconds
Time After: 0.00622 seconds
Time Taken: 0.00235 seconds
Time Before: 0.00302 seconds
Time After: 0.00961 seconds
Time Taken: 0.00660 seconds
Time Before: 0.01192 seconds
Time After: 0.01238 seconds
Time Before: 0.01391 seconds
Time After: 0.01506 seconds
Time Taken: 0.00115 seconds
Time Before: 0.01132 seconds
Time After: 0.01524 seconds
Time Taken: 0.00392 seconds
Time Before: 0.02033 seconds
Time After: 0.02047 seconds
Time Before: 0.02222 seconds
Time After: 0.02342 seconds
End call of global.php: 0.02523398399353
Time Before: 0.02657 seconds
Time After: 0.02672 seconds
Time Before: 0.02870 seconds
Time After: 0.03014 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=31151', badlocation = 1
Time Before: 0.04278 seconds
Time After: 0.04317 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.04177713394165 seconds with 9 queries, spending 0.0078511238098145 doing MySQL queries and 0.033926010131836 doing PHP things.
