Time Before: 0.00165 seconds
Time After: 0.00221 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00228 seconds
Time After: 0.00284 seconds
Time Before: 0.00307 seconds
Time After: 0.00316 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00378 seconds
Time After: 0.00577 seconds
Time Taken: 0.00199 seconds
Time Before: 0.00321 seconds
Time After: 0.00917 seconds
Time Taken: 0.00595 seconds
Time Before: 0.01118 seconds
Time After: 0.01153 seconds
Time Before: 0.01345 seconds
Time After: 0.01474 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01056 seconds
Time After: 0.01493 seconds
Time Taken: 0.00437 seconds
Memory After: 2,261.719 KB
Time Before: 0.02018 seconds
Time After: 0.02038 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.02236 seconds
Time After: 0.02356 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.02527117729187
Time Before: 0.02660 seconds
Time After: 0.02684 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.02872 seconds
Time After: 0.03020 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=31176', badlocation = 1
Time Before: 0.04248 seconds
Time After: 0.04294 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
Page generated in 0.04158616065979 seconds with 9 queries, spending 0.0078597068786621 doing MySQL queries and 0.033726453781128 doing PHP things.
