Time Before: 0.00138 seconds
Time After: 0.00188 seconds
Time Before: 0.00195 seconds
Time After: 0.00245 seconds
Time Before: 0.00268 seconds
Time After: 0.00283 seconds
Time Before: 0.00346 seconds
Time After: 0.00614 seconds
Time Taken: 0.00269 seconds
Time Before: 0.00287 seconds
Time After: 0.01008 seconds
Time Taken: 0.00721 seconds
Time Before: 0.01238 seconds
Time After: 0.01275 seconds
Time Before: 0.01521 seconds
Time After: 0.01657 seconds
Time Taken: 0.00136 seconds
Time Before: 0.01171 seconds
Time After: 0.01674 seconds
Time Taken: 0.00503 seconds
Time Before: 0.02346 seconds
Time After: 0.02362 seconds
Time Before: 0.02608 seconds
Time After: 0.02739 seconds
Time Taken: 0.00131 seconds
Time Before: 0.03160 seconds
Time After: 0.03179 seconds
Time Before: 0.03488 seconds
Time After: 0.03631 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=31196', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.05142 seconds
Time After: 0.05169 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
