Time Before: 0.00261 seconds
Time After: 0.00322 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00329 seconds
Time After: 0.00380 seconds
Time Before: 0.00409 seconds
Time After: 0.00421 seconds
Time Before: 0.00493 seconds
Time After: 0.00747 seconds
Time Taken: 0.00254 seconds
Time Before: 0.00426 seconds
Time After: 0.01104 seconds
Time Taken: 0.00679 seconds
Time Before: 0.01345 seconds
Time After: 0.01385 seconds
Time Before: 0.01520 seconds
Time After: 0.01660 seconds
Time Taken: 0.00139 seconds
Time Before: 0.01283 seconds
Time After: 0.01678 seconds
Time Taken: 0.00395 seconds
Time Before: 0.02331 seconds
Time After: 0.02344 seconds
Time Before: 0.02573 seconds
Time After: 0.02739 seconds
Time Taken: 0.00166 seconds
End call of global.php: 0.029159069061279
Time Before: 0.03055 seconds
Time After: 0.03071 seconds
Time Before: 0.03281 seconds
Time After: 0.03423 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=31213'
Time Before: 0.04661 seconds
Time After: 0.04701 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.045693159103394 seconds with 9 queries, spending 0.0087354183197021 doing MySQL queries and 0.036957740783691 doing PHP things.
