Time Before: 0.00195 seconds
Time After: 0.00249 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00256 seconds
Time After: 0.00304 seconds
Time Before: 0.00332 seconds
Time After: 0.00349 seconds
Time Before: 0.00433 seconds
Time After: 0.00728 seconds
Time Taken: 0.00295 seconds
Time Before: 0.00358 seconds
Time After: 0.01105 seconds
Time Taken: 0.00748 seconds
Time Before: 0.01283 seconds
Time After: 0.01331 seconds
Time Before: 0.01586 seconds
Time After: 0.01735 seconds
Time Before: 0.01222 seconds
Time After: 0.01752 seconds
Time Taken: 0.00530 seconds
Time Before: 0.02320 seconds
Time After: 0.02343 seconds
Time Before: 0.02542 seconds
Time After: 0.02676 seconds
Time Taken: 0.00134 seconds
Time Before: 0.02966 seconds
Time After: 0.02990 seconds
Time Before: 0.03185 seconds
Time After: 0.03328 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=31300', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04563 seconds
Time After: 0.04596 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
