Time Before: 0.00770 seconds
Time After: 0.01198 seconds
Time Taken: 0.00428 seconds
Time Before: 0.01206 seconds
Time After: 0.01250 seconds
Time Before: 0.01269 seconds
Time After: 0.01282 seconds
Time Before: 0.01359 seconds
Time After: 0.01573 seconds
Time Taken: 0.00214 seconds
Time Before: 0.01287 seconds
Time After: 0.02078 seconds
Time Taken: 0.00791 seconds
Time Before: 0.02664 seconds
Time After: 0.02713 seconds
Time Before: 0.03027 seconds
Time After: 0.03146 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.02589 seconds
Time After: 0.03169 seconds
Time Taken: 0.00580 seconds
Memory After: 2,261.719 KB
Time Before: 0.04844 seconds
Time After: 0.04860 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.06064 seconds
Time After: 0.06194 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.064299821853638
Time Before: 0.07266 seconds
Time After: 0.07282 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.07572 seconds
Time After: 0.07715 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=31305', badlocation = 1
Time Before: 0.09377 seconds
Time After: 0.09417 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
Page generated in 0.092829942703247 seconds with 9 queries, spending 0.0078351497650146 doing MySQL queries and 0.084994792938232 doing PHP things.
