Time Before: 0.00366 seconds
Time After: 0.00494 seconds
Time Before: 0.00504 seconds
Time After: 0.00548 seconds
Time Before: 0.00582 seconds
Time After: 0.00598 seconds
Time Before: 0.00679 seconds
Time After: 0.00969 seconds
Time Taken: 0.00290 seconds
Time Before: 0.00604 seconds
Time After: 0.01388 seconds
Time Taken: 0.00784 seconds
Time Before: 0.01688 seconds
Time After: 0.01728 seconds
Time Before: 0.01998 seconds
Time After: 0.02122 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01614 seconds
Time After: 0.02144 seconds
Time Taken: 0.00530 seconds
Memory After: 2,261.719 KB
Time Before: 0.02944 seconds
Time After: 0.02960 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.03472 seconds
Time After: 0.03597 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.038224935531616
Time Before: 0.04038 seconds
Time After: 0.04060 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.04299 seconds
Time After: 0.04443 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=31347'
Time Before: 0.05737 seconds
Time After: 0.05764 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.056439876556396 seconds with 9 queries, spending 0.0084908008575439 doing MySQL queries and 0.047949075698853 doing PHP things.
