Time Before: 0.02851 seconds
Time After: 0.03477 seconds
Time Taken: 0.00626 seconds
Time Before: 0.03486 seconds
Time After: 0.03528 seconds
Time Before: 0.03553 seconds
Time After: 0.03566 seconds
Time Before: 0.03637 seconds
Time After: 0.03913 seconds
Time Taken: 0.00275 seconds
Time Before: 0.03574 seconds
Time After: 0.04402 seconds
Time Taken: 0.00828 seconds
Time Before: 0.05198 seconds
Time After: 0.05239 seconds
Time Before: 0.05584 seconds
Time After: 0.05715 seconds
Time Taken: 0.00131 seconds
Time Before: 0.05122 seconds
Time After: 0.05742 seconds
Time Taken: 0.00620 seconds
Time Before: 0.09498 seconds
Time After: 0.09514 seconds
Time Before: 0.11326 seconds
Time After: 0.11454 seconds
Time Before: 0.12328 seconds
Time After: 0.12348 seconds
Time Before: 0.12663 seconds
Time After: 0.12819 seconds
Time Taken: 0.00156 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=31409', badlocation = 1 WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.14523 seconds
Time After: 0.14548 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
