Time Before: 0.00147 seconds
Time After: 0.00198 seconds
Time Before: 0.00205 seconds
Time After: 0.00276 seconds
Time Taken: 0.00071 seconds
Time Before: 0.00307 seconds
Time After: 0.00323 seconds
Time Before: 0.00389 seconds
Time After: 0.00666 seconds
Time Taken: 0.00277 seconds
Time Before: 0.00328 seconds
Time After: 0.01002 seconds
Time Taken: 0.00674 seconds
Time Before: 0.01181 seconds
Time After: 0.01228 seconds
Time Before: 0.01477 seconds
Time After: 0.01626 seconds
Time Taken: 0.00150 seconds
Time Before: 0.01120 seconds
Time After: 0.01644 seconds
Time Taken: 0.00523 seconds
Time Before: 0.02196 seconds
Time After: 0.02217 seconds
Time Before: 0.02408 seconds
Time After: 0.02531 seconds
Time Before: 0.02820 seconds
Time After: 0.02837 seconds
Time Before: 0.03033 seconds
Time After: 0.03176 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=31421' WHERE sessionhash = '785a5ccc852039ad054a2e3a39163c15'
Time Before: 0.04414 seconds
Time After: 0.04711 seconds
Time Taken: 0.00297 seconds
Memory Before: 4,911.656 KB
Memory After: 4,911.898 KB
