Time Before: 0.00131 seconds
Time After: 0.00175 seconds
Time Before: 0.00181 seconds
Time After: 0.00224 seconds
Time Before: 0.00240 seconds
Time After: 0.00252 seconds
Time Before: 0.00313 seconds
Time After: 0.00569 seconds
Time Taken: 0.00257 seconds
Time Before: 0.00256 seconds
Time After: 0.00905 seconds
Time Taken: 0.00648 seconds
Time Before: 0.01089 seconds
Time After: 0.01133 seconds
Time Before: 0.01278 seconds
Time After: 0.01449 seconds
Time Taken: 0.00171 seconds
Time Before: 0.01029 seconds
Time After: 0.01466 seconds
Time Taken: 0.00436 seconds
Time Before: 0.01956 seconds
Time After: 0.01975 seconds
Time Before: 0.02157 seconds
Time After: 0.02284 seconds
End call of global.php: 0.024426937103271
Time Before: 0.02574 seconds
Time After: 0.02589 seconds
Time Before: 0.02816 seconds
Time After: 0.02961 seconds
SET lastactivity = 1788874141, location = '/forums/private.php?do=newpm&explain=1&u=31422', badlocation = 1
Time Before: 0.04182 seconds
Time After: 0.04214 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.040918827056885 seconds with 9 queries, spending 0.0086390972137451 doing MySQL queries and 0.03227972984314 doing PHP things.
