Time Before: 0.00465 seconds
Time After: 0.00581 seconds
Time Taken: 0.00116 seconds
Time Before: 0.00588 seconds
Time After: 0.00628 seconds
Time Before: 0.00653 seconds
Time After: 0.00671 seconds
Time Before: 0.00736 seconds
Time After: 0.00958 seconds
Time Taken: 0.00222 seconds
Time Before: 0.00676 seconds
Time After: 0.01360 seconds
Time Taken: 0.00684 seconds
Time Before: 0.01628 seconds
Time After: 0.01668 seconds
Time Before: 0.01910 seconds
Time After: 0.02033 seconds
Time Before: 0.01563 seconds
Time After: 0.02058 seconds
Time Taken: 0.00495 seconds
Time Before: 0.02876 seconds
Time After: 0.02890 seconds
Time Before: 0.03119 seconds
Time After: 0.03247 seconds
Time Before: 0.03691 seconds
Time After: 0.03717 seconds
Time Before: 0.03985 seconds
Time After: 0.04184 seconds
Time Taken: 0.00198 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=31484', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.05986 seconds
Time After: 0.06026 seconds
Memory Before: 4,288.836 KB
Memory After: 4,289.063 KB
